Tnyurt
- Messages
- 6
- Reaction score
- 0
- Points
- 1
I have a well that I am using to feed 2 houses. I do not know GPM, well Hp, or depth. It goes into a 20 gallon well-x-troll pressure tank with a 40-60 pressure switch. The first house is 100 feet away. It has 5 bathrooms, 2 water heaters and 2 kitchens but water pressure is always good. I have 2 hydrants close by that also have great pressure. The issue is the other barn/house. I am in the process of converting it into a living space. It is about 200 vertical feet and 500 running feet away. There is a hydrant there now but the pressure varies greatly. From a good flow to not much at all. If you try to use your finger on the end of the hose to spray it, water will almost stop flowing. I do have a psi tester coming tomorrow. I would like a constant flow to the new house. Thought about a bigger pressure tank to get more draw down, maybe a holding tank and pressure pump, a pressure tank in the new house, pressure booster system?? I can't seem to get a answer so I am leaving it up to others experiences here.
Thanks in advance.
Thanks in advance.
