Troy K
Hello , so when I turn on the water everything runs fine until the submersible pump kicks on, it runs for 15 to 30 seconds and one side of the double 15 amp breaker trips. The other 15 amp breaker does not trip ever and the water will continue with same pressure for a couple minutes and then the pressure will drop. While the pump is running I can close the breaker that is tripped and it will hold for another 15 seconds or sometimes two seconds and it will trip again. Once I turn the water off I can close the breaker and most of the time it holds until the pump turns off. I have replaced the breaker with a new 15 amp double pole, I have good voltage to the pressure switch. I disconnected the wires running from the switch to the underground pump and only have a continuity tester and I touch the Black and white wire going to submersible pump and the continuity tester showed continuity. Am I supposed to I have Continuity through the pump? Any ideas what this could be? Or some advice on my next step thank you.
