It is time to replace my well pump and looking for advice. I have a dug well. The original boring is 64 feet but recently verified at 61 feet (after 35 years of silt). The static water level is at 32 feet. This is a low yield well (approx. 3 gpm). Casing is 24" diameter.
I plan to install a 240V submersible pump. The current 110V jet pump (2 line) ready for replacement. I am less concerned about cost as I am about efficiency and longevity. The pump will supply the house, as well as several outdoor agricultural style hydrants.
Looking for advice on horsepower requirements, specific features I should look for or consider, and pressure switch/tank/etc. requirements and recommendations. Due to the low yield, self priming is a must.
More background: the current jet pump is in the well casing, pressure switch is on the pump, pressure tank is about 100 feet away in the house with minimal elevation change from pump to tank. Given the current setup, I am not opposed to relocating some or all of the components if appropriate. For instance, the location of the pressure tank or the pressure switch. The house is 2-story with 3 full baths along with normal washer, dishwasher, etc.
I have adequate plumbing experience, have worked on the existing pump, replaced pressure tanks, etc. as well as installed all hydrants.
Thank you.
Paul
Thank you.
Paul
