Bill Arden
Computer Programmer
It's strange how much cooling you need for only 90F outdoor temperatures.
It's examples like this that shows how much the local climate makes a big difference.
FYI: Here in MN the ground temp is around 65F and the outdoor temp ranges from -40F to +100F
Some thoughts
1. Valveman: Why would a "jet pump" be needed when the water is already at the surface and thus a regular "centrifugal pump" would work for the booster pump?
2. With such a low static water level, mild warm climate, and high water temperature you might be better off with "air source".
Closed loop would be better, but is probably too expensive until cheaper drilling is available.
(Vertical Ground source wells are getting cheaper. I'm guessing half price per decade?)
3. How is the Day/Night temps? A nighttime "ice making" system might be cheaper to run.
4. insulation R-Values, Radiation shields, Solar shading?
Some thoughts
