TVL
My feeling is....the well driller/pump installer you trusted to do the work knows the area better than the rest of us do, I for one wouldn't want to second guess his expertise in the local hydrology. He has the pump set at that depth for a reason and I think you should ask him if it's ok to set it a shallower depth.
Well, here is the rest of that story. The local well digger wasn't sure what was happening with the original well - was it going dry? had the well screen gotten plugged from sand over the years and simply wasn't allowing proper flow? ...... thus the reason for blowing it out which still didn't resolve my issue.
So, he then suggested we drill a new well in hopes we could once again get a sufficient quantity of water. He is also the one that suggested we drill a new well somewhere near the original ..... so I picked a spot just 15 feet away. After drilling, he felt fairly confident we were in the same sand aquifer as the original well. He also confirmed the static water level was the same in both.
Since I had been experiencing issues with pumping the well dry in the original well and he wasn't sure if it was because the well screen had become partially plugged over the years OR if I was indeed running out of water because the aquifer could no longer support the demand, he chose to put the pump near the bottom in the new well. He felt this was the safest thing to do at the time and I certainly agreed. However, I have since monitored the new well very closely and now know the exact static water level at rest and during operation. Based on my data is why I felt it might be best to raise the pump to address any cooling concerns I have. But again, I wasn't or still don't know if there are other things I should be concerned with if the pump is raised a few feet ............. thus my reason for asking the experts.
Anyway, maybe I should just let this post die, unless someone wants to address my main concern which is item #1 in my original post. Thanks so much!
