I just removed the toilet in our bathroom so it could be cleaned underneath and then caulked as it was starting to stink. The floor is osb and the flange is attached to it. There is a sub floor of about 1/4" that isn't under the flange ( sub floor cut around flange installed after flange was already in)and linoleum flooring on top of that. From what I remember the flange was either level or just slightly higher than to top of the vinyl flooring. I used a regular was ring with the plastic leak funnel in it. Should I have used the extended height wax ring? If not at what point should one be used with respect to the height of the flange in relation to the floor?
