Water pressure is not constant
Scottnot So Handy
Michigan
Good Morning and hello,
Fairly new to this forum but after reading some awesome articles it is now in my favorites!
Anyway I am hoping you guys can give me some advice. As my name states I am not very good at being a handy man but it is not from lack of effort!
Anyway my problem is my water pressure through out the house goes up and down. Doesn't matter day or night. Also I noticed yesterday while I was in the basement a switch (assuming water pump switch) would keep clicking when the water was running. It would click twice, one right after another, then stop for about 30 seconds and start again. Also the copper pipe attached to the pressure tank vibrates alot every time it clicks. This goes on for awhile then it shuts off.
back ground information
I am on a well
I recently had the hot water heater replaced ( 2 weeks ago)
I replaced the pressure tank about 10 years ago.
Hopefully this is enough to get some advice from you guys.
Thanks in advance!!!
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Not really.
What kind of pump, jet or submersed? What is the pressure guage showing through all that? Have you checked the precharge on the bladder?
From the sounds of it, it may be too late to save the pump. It sounds like it is short cycling and the thermal overload is tripping.
Pump cycling on and off? That is usually a sign of a "waterlogged" pressure tank so you are operating on "pump pressure" which will rise and fall as the pressure switch turns the pump on and off.
Scottnot So Handy
Michigan
Thanks LL and hj
I will go home at lunch and check the pressure. Not sure what kind of pump it is, is there a way to tell what kind you have?
Can I drain the water out of the pressure tank?
Thanks again
quote; Can I drain the water out of the pressure tank
Depending on the type, you may just have to put air INTO it, but there is a specific process to do it. If you depress the air valve and water comes out, then you need a new tank.
Scottnot So Handy
Michigan
HJ, you where right, it was the pressure tank. Tank was completely full of water. Installed a new one and the water pressure is good!
