MikeG
I have a 3 year old WH that has a white crust on the hot side at the male/female coupling between the copper pipe and the brass fitting going into the WH. When the plumbers installed the WH they specifically said that they were using a brass fitting so that there would not be a metalergic reaction between the copper and the galv. steel at the tank fitting.
It appears the the white crust may be corrosion. What could be causing it? No leaks yet.
I was going to call the plumbers that did the installation to have them check it out. My guess is all they should have to do is replace the brass fitting.
