FLhome0wner
I'm a home owner located in Florida (IPC/FBC/FRC building codes), I'm installing a new Rheem hybrid water heater that I've had in my garage for a while as I remodeled the rest of my house. I attempted to plumb this per all applicable codes, and manufacturer recommendations. I have concerns that I don't have the recirculation hot water return to the cold return properly heat trapped and I have have water rising from my recirculation line going up to my thermal expansion tank and my vacuum relief valve. Is this something to be concerned about?
Also, so far I haven't been able to get my recirculation pump to be able to pump water around the loop quicker than 30 minutes (if it's even pumping). I estimate that the volume of my loop is 1.5 gallons and the pumps max flow rate is 2.2 gallons per minute. I think there is air in the lines, but it didn't get better when opening all the valves upstairs and running hot water.
Lastly, I wasn't sure how to interpret the code the the TPR valve drainage tube. I had some extra copper and fittings, so I used that. I installed it to the rim of the pan, which is ~2 inches tall. Code states it should be between 1.5-6 inches above the floor or flood rim of the receptacle. Does the pan count as the receptacle? Is the purpose of the gap for backflow prevention?
Anything else I should be careful concerned about with this installation? This will be inspected, I just haven't called the inspection yet.
I attempted to plumb this as follows while also meeting requirements for my plumbing codes: https://www.caleffi.com/usa/en-us/blog/temperature-creep-hot-water-recirculation
I've added a photo of it's current state and some in process photos.
