Tim Leiter
Tim Leiter New Member
Saturday
pennsylvania
I'm having a hard time finding the cause of water hammer and pipes shaking when pump cuts off. Pressure in holding tank good at 28 psi. Pulled the pump up to pit less adapter to check if it was holding water, so that check valve is good down at the pump. Replaced the check valve right before the holding tank and it made no difference. I do have a gauge right inside the house where the line comes in. The gauge will read accurately to pressure tank gauge when the pump is running and when it cuts off the gauge goes to 0 for a few seconds and then starts creeping up to about 12-15 psi with no pump running in about 20 seconds. It does not loose pressure sitting idle, so I don't think I have a leak underground. The pressure switch at the tank is set to 30/50.
Saturday
pennsylvania
