Vessel Faucet Hose - Where to buy locally?
qtrmiler347
Cooper City, FL
I have one of these made in China Vessel Faucets and the hose, at the factory crimp (end with the two o-rings) is leaking, so the hose is garbage. I have found them on E_b_a_y and other non-local sources, but I would like to go somewhere and buy it locally in the Miami/Fort Lauderdale FL area if possible. Is this something a good plumbing supply store might have? Home Depot & Lowes don't have these.
Here is a pic of the end that goes into the faucet. The other end is a standard size nut with seal in it.
Thanks.
Shacko
Master Plumber-Gas Fitter
Rosedale, Md
You should take it to a plumbing supply and just match the o-rings and replace them, put a little plumbers grease on them when you hook them up
They are probably proprietary with that manufacturer, although other companies use hoses that look similar. It is NOT an "over the counter" item, but must be ordered from the manufacturer, assuming you can find him. The thread, AND "O" ring o.d. MUST be exactly the same as yours.
