Thats good to know , Not sure how it might apply perhaps If IPC he could eliminate the stack for the lav and just wet vent the w/c with the kitchen and lav ?Most of MO uses IPC, but KC, MO uses UPC plumbing code.
Jeff, I am fine putting a 4th riser in if this certainly satisfies UPC. I am putting in a 6" wall so do you see a potential structural issue with two risers in one stud cavity? If not, I will put them at 12" and move on.Thats good to know , Not sure how it might apply perhaps If IPC he could eliminate the stack for the lav and just wet vent the w/c with the kitchen and lav ?
I probably should have been specific, (I modified my post to reflect this information), they are off less than 1/4" per/ft. Roughly speaking, yes, in 2', one riser goes 1/4" 1 direction and the other pipe goes 1/4" in the other direction.1/4" is well within tolerances for this application. I bet you could close that gap with hand pressure.
You will need to stake things so they don't get pushed around by the concrete while the slab is poured--I have no experience with that, so can't advise on a good approach. But you could probably make the 1/4" go away when securing it for the pour, not that you need to.
Cheers, Wayne
There are many configurations where separate 3” vertical waste pipes would be beneficial, but as far as your layout is concerned you’re fine with one. If necessary, you could always turn one 3” into two 3” but on the vertical up towards the ceiling by using a wye and a street 45 rotated parallel with the top of the wye.Jeff, perhaps my rationale for the two risers was simply so each bathroom could have its own branch down to the trunk, then I could plumb both bathrooms using the example that Terry used to post all the time.
I am guessing based on your comment that I could easily combine both upstairs bathrooms into one 3" branch?
Wet vents are awesome IMO. Nowadays many municipalities require us to wet vent as much as possible when below the flood-rim.Points are well taken - I think i understand the basic holdup:
The vent for the downstairs WC either has to be a dry vent, or be wet vented via the first floor lavatory (not kitchen sink, etc). So if I could accomplish that. It really leaves the other two drops open for whatever I want (without the upstairs bathroom sharing the same riser as the downstairs kitchen sink).
Jeff, you are getting close, I have an upstairs area, but I am not really sure what is going to happen and when with respect to plumbing. I'm trying to keep a blank canvas in case we find a need. At a minimum, I would assume at some point down the road, the 2nd story will at least get a full bath, hence the original drawings. Also know that the way I am handling the area above these stubs, is I will have plenty of space to run drain pipes to other areas of the building.
I would be comfortable saying that at most, the second story would see 2 full bathrooms. It seems like an additional riser between studs, downstream of the first floor WC would allow me to simply copy and paste the same upstairs bathroom drain design a second time? Something like this perhaps:
From my research, it seems that all of this together is still suitable for a 3" main line. know that I will be switching to a 4" outside of the foundation.
