Two Drains...
OldPete
DIY Senior Member
NJ
I have a drain that goes to my tub and one that goes to my shower. When I drain the tub I see a slight "bubbling/gurgling" in the drain of the shower. When it is all over there is still plenty of water in the trap of the shower, but I'm curious if this is normal or not. There is no chance for a clog since this is new work, done by a licensed plumber. He indicated that this is fine and normal as the trap is still full.
What say you guys?
OldPete
DIY Senior Member
NJ
What to do? It passed inspection, plumber says it is just the way it is due to the location of fixtures. :confused:
gurgle
It may be the way it is because of the location of the fixtures, but it is also because he must have done the piping improperly, even if it was inspected. He probably has the two connected together before they reach the vent and the venturi effect of the tub water draining is pulling air through the shower drain. It is siphoning it, but there is enough residual water to maintain the seal. Run some water in the shower to fill the trap, measure how far down the water level is, drain the tub, and then remeasure. If the water level is lower you are getting siphonage and that is not normal.
OldPete
DIY Senior Member
NJ
Thank you hj. I'll take the measurements you indicated and post back in a day or two. Thanks again.
