Toto Gwyneth/Drake II/UltraMax???
organic_smallhome
New Hampshire
I thought we had finally decided to purchase the Promenade, but one last trip to the bath store convinced my husband that he prefers the Drake II (formerly the Gwyneth?). Doing research on it has confused me a bit. This is what I think is the correct lay of the land:
The name "Gwyneth" was changed to "Drake II."
The "Ultramax" is the old "Gwyneth" but is a one-piece toilet.
The "Drake II" is also the old "Gwyneth," but is the two-piece toilet.
The "Drake II" comes with CEFIONTECT, an elongated bowl (no round bowl available), ADA compliant seat height, double cyclone rinse, requires a 12" rough, and is 1.28, but can be converted to 1.6, if necessary. Correct?
If so, my question is: Is converting the Drake II to 1.6 difficult for my plumber to do, and does it affect the quality of the flush or cause more problems down the line? (We currently have a 14" rough, but my plumber is moving it to 12" for us.)
Another question: Here's the spec sheet I found that Terry posted:
https://terrylove.com/pdf/cst454_spec.pdf
If I order this toilet, should I order it with this model # (CST454CEF(G), as a "Drake II," even though it's listed as a "Gwyneth"?
Finally, in selecting "Cotton White" or "Colonial White," which is the better "generic" white? We purchased this vanity, which as a very creamy, bright white sink.
Thank you for all your help.
Toto uses a 3" flapper, for their flushvalve between the tank and bowl.
They use a 2-1/8" trapway from the bowl to the floor flange.
Converting back to 1.6g takes about 30-seconds, and you can do it yourself (basically, take the weight off the flapper, or replace it). But, try it the way it comes, it works. Worse comes to worse, you can hold the handle down a bit and it will empty the tank more.
organic_smallhome
New Hampshire
Thanks. My concern about 1.28 v. 1.6 is because I think I read somewhere on the forum--I think it was HJ who stated it (but not sure)--that the 1.28 doesn't always work as well in old houses.
