DIYMike
- Messages
- 31
- Reaction score
- 0
- Points
- 0
Shoulda, coulda, woulda: Replaced the flange when I had easy access to the floor, raising the height to accommodate future 1 7/8" of tile/substrate.
didn't. oops.
Where I am: Tile complete. Net height differential from finished floor to Flange top: 1 3/8". (Easy access to complete PVC Flange surface. Flange is in good shape, bolted to the OSB subfloor. I've got 5/8" ply, 1/4" hardi, and 1/2" tile installed around that. No "easy" access to plumbing now.)
I've got a stack of white plastic 1/4" extenders that I think I can sililcone together and press into a pretty solid stack. I'm guessing 5 or 6 would do the trick.
Should I use silicone to attach the stack to the flange? There are screwholes aligned in the stack, but they do not allign with the flange holes. I would need to screw into the flange top, and that looks pretty risky.
Also, I tried using a "waxless" extender in another room, and was planning to use that, but the flange in this instance is angled and there is no room to get a vertical seal inside the flange. I liked the waxless idea, and the seal seemed to work well. Suggestions?
Thank you
- Michael
didn't. oops.
Thank you
- Michael
