As part of shower remodel, new supply lines were run to change location of shower valve. We were not aware that hot and cold lines were reversed.
Fusion Hardware brand thermostatic shower valve was installed and does not mix hot and cold water; it is either all hot or all cold. Fusion has sent replalcement cartridge and check stop valves but same problem. Our plumber says it should not matter that hot and cold lines were reversed.
Would appreciate any input before going back to Fusion with same complaint. If we switch to a pressure balance valve will the reversed lines still be an issue? From this forum, I understand that type of valve can be rotated.
