Tape / dope on braided supply lines?
DavidTu
Seattle, WA
I thought I'd seen on the forum to NOT put pipe dope and/or plumbers tape on braided supply line connections... but now I don't find the reference. In any case... do these connections take dope or tape? My faucet instructions call for it but I've installed them w/o leaks and without tape or dope previously.
What is best practice on this?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Many of the braided hoses now have O-ring seals and as such don't need to be doped. If they use a metal to metal seal, a little pipe dope is fine but I would never use tape. IMHO tape is for sealing threads and on those hoses the threads don't do the sealing.
Dlarrivee
Canada
If it's a compression fitting, you don't use tape or dope.
The compression ring/ferrule seals the joint, over tightening is also bad news.
Tape and dope are for TAPERED threads, where the threads do the sealing.
Jimbo
San Diego, CA
Braided supply lines normally have a rubber gasket seal...tape would intefere. Some brands use a 'bullnose' which simulates an actual compression ring. It is for metal-to-metal seal, and again, NOT tape or dope
No tape or dope.
LLigetfa
NW Ontario, Canada
THe problem with the bullnose is that it is of a much harder metal and so does not truly simulate a compression ring, which as the name implies, compresses to seal not only against the tube but also against the machined tapers. Any imperfection in the machined faces can cause a leak.
And yet plumbers install them all the time without dope
