Daler
We have a recently discovered problem with a leak in our supply line from the meter box.
Got home from a trip and saw water flowing across our driveway.
Dug up the line and also found the installers (from 40 years past) had kinked the copper so they could get the correct angle into the meter box.
The kink decided to spring a leak and pissed water to the tune of a large water bill.
Anyway, I’m trying to figure out the best way to permanently repair this line (I’ve temporarily wrapped the leak with EPDM and screw clamps). As you may see from the photos, there is a brass union before the 3/4” copper goes into my gate valve.
What I’d like to do is to cut out the kinked section all the way back to the valve (about 2.5 feet), and somehow patch in another section, but this time bypass the valve (seized open so get rid of it) and connect directly to the ¾” (MPT) stem on the meter unit. The meter assembly has a good on/off ball valve.
I was thinking of soldering a ¾ 45 deg elbow onto the ¾ copper and a 4”x ¾ copper stub onto that elbow. Then using sharkbites, splice in a section of ¾ superpex with a ¾ x ¾ sharkbite FNPT at the other end connecting to the ¾ MPT. This might do away with any union.
But there are 2 problems with that idea: the ¾ copper is soft rolled (not completely round) so sharkbite may not work (hence using an elbow), and how do I manage to flex the pex into place with the sharkbites at either end of it?
Appreciate your thoughts on a workable solution.
