Soft water not slippery
Mark Martinez
Evansville, IN
First post...
I just replaced a 11y/o Kenmore 350 softner that was producing low water pressure due to bad resin. I just bought a similar Kenmore model and installed it on Tuesday. I immediately noticed my water pressure back to normal but the water doesn't have that slippery feel to it. I did a water test and the hardness is 0-2. I also ran the hot and cold water for 30 minutes. It's day 2 and still don't have that slippery feel. Is it possible to have soft water without the feel or should I just be patient and wait? I had it with my old softener.
Any help or knowledge is appreciated
Mialynette2003
Ocala, Florida
I had a customer tell the same thing after moving her unit from one house to another. The water was soft but not slippery. What kind of test kit showed your hardness at 0-2? Is that 0-2 GPG or PPM?
Mark Martinez
Evansville, IN
I had a customer tell the same thing after moving her unit from one house to another. The water was soft but not slippery. What kind of test kit showed your hardness at 0-2? Is that 0-2 GPG or PPM?[/QUOTE
I used a $10 kit from Menards (Filtermate). It read 0-2 GPG. From the municipal water quality report it says it's 12.9 GPG and 221 mg/l.
DonL
Houston, TX
First post...
You should give it time to work.
And do a manual rejuvenation, Instead of wasting water to make the timer trip.
If you like slippery, some soaps slip better than others. Look for the soap on a rope.
Good Luck, With your new junk.
Sorry I just had to.
Mark Martinez
Evansville, IN
Thanks, I never thought of that...
