mb1280
It won't let me upload my "how to" PDF to this site . . . it says "File too big" . . . so here it is on my Google Docs:
pop-up-plug.pdf . . . https://drive.google.com/open?id=1QBSK7rZqwEby5yXoBY-wlWVRPkTKT2aN
In this PDF is the info on what I did to make a plug, for the Pivot Nut / Cap hole.
Questions on the plug:
1.) How do you think that 1/16" Neoprene seals against the beveled edge, inside of the cap?
2.) Faucet Washers are thicker. Would that seal be more, or less, effective?
3.) Do you think a lock nut is necessary? . . . Probably not, since there is no vibration?
Questions on the Lift Rod:
1.) Do all bathroom sink faucets have an optional hole plug for the Lift Rod?
2.) Do you usually have to send away for a Lift Rod hole plug?
3.) Are Lift Rod hole plugs waterproof?
From clicking around, I see that people have complained that water can get into the cabinet, through the Lift Rod hole, so that's another reason you don't want to use it.
I have to see about getting Lift Rod hole plugs for my Moen bathroom faucets.
In the meantime, I have put a piece of Scotch tape over the holes, and that even seems to be good enough.
This looks good, in appearance, but doesn't address hair:
https://www.calfaucets.com/news/cal...es-zerodrain-the-world-s-first-pop-down-drain
I wonder about clean-ability, also.
I rarely need a sink full of water. When I do, I have a simple, easily cleanable, rubber stopper for that.
As I see it, keeping hair out, clean-ability, and being leak-proof are the priorities.
When was the first pop-up drain? Sometime in the 50's? Time has shown how:
1.) It lets hair down the drain - which you don't want.
2.) Black slime accumulates on the sides of it - you don't want wafts of that scent in your face.
3.) It impedes the flow of water, creates a place where crud can accumulate, and requires effort to thoroughly clean - self-explanatory
The Lift Bucket in the tub is similar.
