mb1280
This is what I determined is the best thing to do, to prevent slow drains (PDFs on my Google Docs):
I make a solution of lye - I learned how to do this from soap making:
slow drain.pdf . . . https://drive.google.com/open?id=17T57CkslK5fneTMKSd7xD5NScxjTnk2o
An initial, good cleaning with lye, Tub and Sink Shrooms in place, then, you can use less hazardous, enzymatic cleaners.
This is my post / questions on the Tub and Sink Shrooms / How to cap the Pivot Nut . . . https://terrylove.com/forums/index....p-cap-pivot-hole-tubshroom-lift-bucket.85422/
Good video link in here of where stuff accumulates, that creates a slow drain:
tub drain research.pdf . . . https://drive.google.com/open?id=1aEGeL54EhIcqPF30P4ahOFQdFdxduZBb
The only thing I wonder about today, is:
1.) Lye vs. Sulfuric acid . . . base vs. acid . . . Is there a dramatic temperature difference between the two? My impression is that acid runs hotter.
2.) Could the temperature that lye goes to, be dependent on what it's dissolving in your pipes? Apparently, it can get hot, but I don't see that when making a solution of it.
3.) If you don't leave the lye solution in your P-Trap for more than 30 minutes, is that the logic behind that it won't deteriorate the glue holding your pipes together?
