Sink (kitchen and bath lav) DWV rough in
Jwray
Virginia
Doing major renovation in old house and totally replacing DWV. Will be installing several bath lavs and one 3-bowl kitchen sink with garbage disposal and dishwasher.
Previously got advice that I like re: the 3-bowl sink. Planning to use 3 individual traps that will attach to 3 drains at the wall (accomplished with a sani T and sani cross stacked. cross will have 2 short arms to left and right with 1/4 bends pointed out of the wall).
My question now is how exact does the rough in have to be horizontally in relation to the drain center lines? If I don't get it in exactly the right place how to I deal with attaching the trap arm to the drain if the arm doesn't intersect the drain at 90 degrees?
Also, is there a standard for the vertical height of the drain inlet for kitchen sink or bath lav?
Thanks,
Joel
drain
The center bowl is usuall shallower than the other two, so use that as the starting point for your "street" sanitary tee above the "back to back" fixture fitting, (not a regular sanitary cross), and then let the other drains' height be determined by that. If you do not get the drains in the exact location, or close enough for the trap swing to reach them then you can use 1/16 or 1/8 bends under the sink to line up with the traps.
Jwray
Virginia
Good news
Thanks again HJ. Appreciate all the quick replies.
I will try to get the rough in as exact as I can, but you know how things can go sometimes between the rough in and finish work - plans change (especially when you don't do this every day :) ).
Good to hear I can "fix" things with some small bends if necessary.
