I am about to install a shower valve in a stand up shower that I am building. I am concerned about maintenace - like what do you do if the valve stops working for some reason after you have tiled.
Most of the installation techniques I have seen look permanent and nowhere have I seen anybody placing in line valves like you would for a kitchen sink. Is that the way things are done? - just assume that nothing goes wrong and if it does tear the shower apart to get at the valve.
I was thinking of installing the valve on the face of a 2x6 screwed into the studs with copper line long enough so that in the future i can come in from the back cut the lines and then unscrew the screws and remove the 2x6 and the faulty valve.
Does this make sense or am I over-engineering?
