I have a 3 knob shower system that has dripped off and on for years. I used to think it was just the diverter valve because symptom is the water is always "stuck" in the pipe and has to be drained but it didn't matter which way the diverter is turned, there is water dripping.
Years ago, I took on the challenge to repair it. Eventually, I ended up replacing all 3 valves by myself (going back and forth to the home center and a lot of cuzzing). It was about a 3 month on and off project in all. I made some notes in my Reader's Digest Home Repair Manual to help me the next time I decided to take on the challenge.
My repair lasted for a number of years but about a year or more ago the constant drip started. I decided to call the plumber rather than try it again. He came over and tightened the the nut on the TOP part of the valves near the stem and charged me $85. I felt like a schmuck. I wrote myself a note so I could remember just what he did and stuck it in my book.
It has been over a year since his visit and the drip from the shower has started again. I got out my note and pulled of the handles. My note says, "Use SMALLER end of socket wrench to tighten the NUT." I tried this but is was too big for the nut.
I'm assuming that my note that says "21/32" is the valve size. The smaller side of my socket wrench says 21/32 and the larger side says 27/32. Before I take out a valve out and jump in the car to buy a smaller socket wrench to tighten the nut I need some answers and guidance.
1. Approximately how often should people replace washers on valves?
size 000 hot and cold washers and a size 00 diverter. I'm up for doing this.
2. Approximately how often should all of these valves be replaced?
I'm not sure about doing this again.
3. When is it a good idea to consider an investment in a whole new set up? I think I've heard of valveless facets and it sounds pretty good to me. Our house was built in 1978. I've been told I'd have to replace the entire shower/tub stall to do this. There is no access to the back of the tub. (Obviously, I'm not doing this myself.)
4. How must I maintain a valveless system compared to what I have? Are there pros and cons to making the switch besides the cost?
5. Would you recommend any better books for plumbing problems? I'd like one that provides a step-by-step for "Dummies" but will caution me about the degree of difficulty. I'd like to have a sense of when I should opt out and call a plumber. I do like learning but I don't want to tackle another plumbing job that is above my abilities.
