Shower/tub combo broken tub spout copper stub out
mhm63
Columbus Ohio
if I cut the copper pipe, can I connect shark bite and still be able to install a new tub spout? or it is better off after cutting it, buy an end cap become a shower only
I dont know how common it is there or with other plumbers but I almost always have a female threded 90 at the bottom and less than 5 percent of time go with a sweat 90 . so you hight be able to get in there with a socket wench and unscrew it or use what we call cow bells to unscrew it those are in expensive set of sheetmetal siockets used in faucet repair.
I would be comfortable making a bigger hole removing the trim around the handle and burning a coupling in that wall Id have squirt bottle handy and wet the inside area and do it !
John Gayewski
Iowa
That loos like a reducer with a piece of 1/2" copper sweat into it. I think i would try to Un sweat it, but it could be very tricky. You might want to call a plumber for this one. There's a chance you'll have to open the wall.
It's worth looking deeper to see if it can be Un threaded.
mhm63
Columbus Ohio
I would be comfortable making a bigger hole removing the trim around the handle and burning a coupling in that wall Id have squirt bottle handy and wet the inside area and do it !.
Thanks. Is the broken part like this behind the wall? this is one piece shower/tub combo,house was built in 1990.
mhm63
Columbus Ohio
Thank you, I saw on youtube someone demolished a shower/tub combo like ours, it looks like shown below.
mhm63
Columbus Ohio
if it is like the picture shown, can I open the acrylic wall bigger, and use a mini tubing cutter shown below to cut the broken pipe?
then I use a sharkbite coupling to connect a tub spout? is this possible?
mhm63
Columbus Ohio
or after I cut the copper pipe, can I use a plug end cap to close the copper pipe in the wall and transfer it to the shower only? is this also possible?
I dont use that type fitting but that is entirely possible . Mine the stub out screws directly in to 90 Actually when I rough it in I stub out with a galvinized nipple at the tub and the shower head. they are temporary and changed out later when setting finish.
I dont know if yours is plumbed the way I described. Shark bite might work the spout be kinda wobbly I suppose temporary it be ok especialy if you are careful adults living there
mhm63
Columbus Ohio
Thank you very much. I will probably give it a try the way that I described. :)
John Gayewski
Iowa
A tub spout with a sharkbite won't really be very good as it will spin.
I don't think the examples you showed is what's on your wall. I can clearly see a reducer with a soldered joint in your closeup picture. The examples you showed are one piece and aren't soldered.
mhm63
Columbus Ohio
do you mean the second picture? the second is the tub spout. the first picture is only a copper pipe, I do not know what is inside because it is dark inside. Maybe after I make the hole in the wall a little bigger, I can see it.
Basilisk
Austin, TX
If the in-wall piece of pipe is not completely chewed up, I think something like this would work:
It's a repair kit for tub spouts, can be soldered in, or, more importantly, epoxied: "when soldering cannot be done, copper extension shall be connected to CTS in wall using specially formulated copper to-copper 2-step epoxy".
Sioux Chief part number is 972-3RAKIT. It's cheap, I would give it a shot.
mhm63
Columbus Ohio
Thank you so much. This is a better way to do it. I saw it says 5/8 inch. will the tub slip on spout work with 5/8?
  • Like
Reactions: GRK
Basilisk
Austin, TX
5/8" is the physical diameter of what we call 1/2" pipe, so all slip on spouts should work. A few retailers for some unknown reason use actual pipe diameter, and in this case the description is just plain wrong, there is no FPT side on this fitting. But that's the right photo and the right part number!
mhm63
Columbus Ohio
Got it. Thank you so much!
