Shower Odor
Jason Kay
West Orange, New Jersey
Hello. Whenever I turn on the upstairs master shower, there's a foul egg/burnt hair odor coming out from the drain. Only occurs in this shower and no other drains have this odor. I've tried grease/hair dissolver many times, vinegar & baking soda, etc. Nothing has worked. I'm assuming the sewer gasses are being "released" when the p-trap seal is broken when the water starts flowing. Doesn't smell when the shower isn't on. There's also a jetted tub in the same bathroom but that doesn't produce any odor when turned on.
Could this be a blocked vent? If so, would this shower be the only area affected? Kind of at a loss. Thank you.
when did it start happening? has bathroom been modified remodeled or something?
I guess running a snake down might help maybe a bunch of hair etc some how effecting trap seal
The smell comes from that shower drain, and there is not a floor drain nearby that you might be smelling, right?
Jason Kay
Nope. No floor drain. Just shower and tub drains.
I snaked the drain with a 25ft.snake...nothing came up. Also, I notices that the standing water in the shower drain trap shakes/vibrates when the toilet in the same bathroom is flushed. Doesn't look like the water level drops but there's definitely movement in the standing water. Would that indicate a venting issue?
yes it does arise question of proper venting. maybe you always had the problem but the pipes just didnt have that stink going on. y6our losing the trap seal and in a properly plumbed system it only can happen by blockage or somethin g like that but I wouldnt assume its built right either
