Hi,
I hooked up a new pump [craftsman 3/4 hp] to a shallow well , depth about 12 feet and got everything running great. I'm also using a 30 gallon Craftsman captive air tank, about 3 years old. This well is only being used for outdoor applications.
Pressure was about 60psi, lots of water, but I did notice the prime would drop off after 5-10 minutes of shut down, so I thought there must be a leak on the suction side, ruled out check valve because it's brand new and comes with the pump [plastic though], but never checked it out,
So after about 5 months of good use, the pressure drops off, slowly to 55, 50, 45 ....... now 40 where it stays solid, sometimes it will go up to 45.
Captive air tank fills good, but I had to adjust it's air pressure since it and the system were at 40,
I've checked suction side for leaks but can't find any, pressure side is rock solid. Is there a better test than soap bubbles?
I'm reluctant to open pump to check impeller & jets because in 15 years I"ve never had to clean a pump on this well & this pump has only been in service for 5 months, though it's a possibility,
a) loses prime when pump is off, did this from first day I hooked it up
b) max pressure is 40psi
c) no leaks on suction that I can see but who knows
Is there a foolproof way to test the suction side without dismantling everything,
Thanks for your help and suggestions,
Jeff
Jeff
