Newbie.
Switch at 40/60. New "H20W-to by water works" tank precharged at 38psi. I decided to check the pressure on my pressure tank. It was 58psi.
This is all installed stuff mind you. And the pump has filled the tank and stopped at 60.
So I let the air out of the tank to set it at 38. Because I thought there was too much air in the tank. I got to thinking about it. Serious Brain Fart Duh. It should have been near 60 because it was at the shut off pressure which is where it should have been. Right?
So to get my tank back at 38psi precharge do I drain the water out of the line and tank and then re precharge it to 38 psi?. Then turn the switch back on to my pump.
Help
Help
