Sand point well placement
Christian Gould
Wisconsin
I am going to try for water with a sand point well in Sawyer County 6 miles SE of Hayward, Wisconsin. I read the previous posts about how to drive the well and those were very helpful.
In Wisconsin every well needs to be applied for and a permit issued before I can drive my own sand point well. The revised state standards (2020) are that the well needs to be located at the "highest elevation (within reason) of the parcel".
I am trying to figure out where to place the well on my land.
The 3 acres fall 50 feet in elevation to a natural spring over the course of the 600 feet of land. The highest point of the land is at the road, 600 feet in distance and 50 feet of elevation from the natural springs.
I plan on putting a cabin 200 feet in from the road, this would be 400 feet from the spring. The cabin location is 10 feet lower in elevation than the road, and 40 feet higher in elevation than the springs. Should I try for water where I want to put the cabin or should I move further down the slope closer to the natural springs keeping in mind that the state rules are that the well is located at the "highest elevation (within reason) of the parcel".
I am not sure if anyone will inspect the well, as the $50 permit can be bought at a gas station the same as a fishing license.
Any ideas where you would put the well?
Christian
I would put the well on the uphill side of the house, maybe 20 to 50 feet out, and on the opposite side of the house from the septic field. I am not a pro.
Any thought of putting the water line below the frost line for year-round use?
Christian Gould
Wisconsin
here is an elevation map of the parcel too.
Upside of the house for better water pressure?
Do you think I will have trouble finding water with sand point?
Contamination... * rolls downhill.
Ask the neighbors. I had presumed that locals told you you would probably be OK.
If it doesn't work, consider a drilled well with a 5 inch PVC casing and a pitless adapter. Yes, big money, but not nearly as much as people pay when the water is far down.
AFAIK, driving a well point is a low cost thing, and if it works, it works.
