Rust spots from soldering?
palpack1
Illinois
The day after our plumber did the tub rough in I discovered tiny rust-looking spots on the floor of the brand new tub toward the front of the tub. Could that be from soldering? Any ideas on removing them? Scrubbing didn't work.
Iron Out is good for rust.
https://www.menards.com/main/grocer...emover-28-oz/io30n/p-1444444183359-c-7097.htm is the small bottle of crystals.
Jadziedzic
Active Member
New Hampshire
Is the finish of the tub chipped where you see the rust spots?
Do you know if the plumber ran water in the tub to verify there were no leaks? Are there galvanized pipe nipples sticking out of where the tub spout or shower arm (if one) would be attached? It might just be bits of rust from inside the nipples that wound up on the bottom of the tub.
Dj2
California
Do this: rub it with a cloth. Is it coming off, and if yes, is the finish on the tub good?
palpack1
Illinois
It is brand new cast iron. No chips in the finish. It does not rub off. Yes, there are rusty pipes sticking out of the rough in shower and tub spout and he did test the water. What does all that tell me? Thanks!
IMHO, nobody should have any galvanized piping in potable water systems. You're just asking for problems.
There are some things that should help remove rust stains, if that's what they are.
One thing you can try is to make a past of borax and lemon juice, rub it on, let it sit for a few minutes, and rinse away. Repeat as necessary. There are some commercial rust removers available, too.
Jadziedzic
Active Member
New Hampshire
The rusty pipes sticking out of the rough in are PROBABLY temporary and SHOULD BE replaced with brass when the plumber installs the trim pieces after the finished wall surface (tile I assume?) has been installed. I would contact your plumber regarding the rust spots - although unlikely, they *could* be defects in the tub finish.
palpack1
Illinois
No worries on the galvanized pipe sticking out. Just placeholder until fixtures are put in place. Iron Out didn't work. I'll try the borax and lemon juice. The Tub was fine when purchased but the spots appeared after construction and rough in. Still a mystery.
FWIW, there is no iron in solder...it's generally silver and tin (older stuff had lead in it)...so, your stain wasn't from soldering. It could be from maybe the flux, but more probably, an iron particle in the galvanized piping that got flushed out and not cleaned up.
But, if there was a defect in the finish, it could be that.
An acid based flux (not supposed to use those anymore) might stain something, but it should still clean off.
A magic eraser can sometimes help without damaging the finish.
