Hids2000
I am installing an out door AC unit and need to run 220v 15 AMP power to it.
My question is can i just use UF 12-3 wires directly from main panel through the wall into the quick disconnect than UF 12-3 into the AC. The run is about 6ft in length.
Do I need to put the UF wire inside a conduit both before and after the disconnect?
If I need to put the UF 12-3 inside of a conduit will a 1/2" metal conduit be big enough?
thanks
thanks
