Retesting well water
Rman
Master mechanic
northern NJ
I had a 325 ft drilled well done 2 years ago today. It tested all within allowable parameters
Do or should I have the water retested again?
No plumbing work done regarding well or pump
Water tastes the same but having sometimes gastro gut disturbances (diarrhea)
Should I just shock the well again the installer used 2 gallon Clorox
I'll need to wait when the temperature is above 10 deg to open well ahead
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
A water test every once in a while is a good idea. Even better idea if you notice health problems. Chlorine might be all you need, but we don't know what your dealing with without a test. Some contaminates can be recurring, which needs to be addressed.
