DIYinATX
EDIT: I'm a dummy. User error, most likely.
See post # 11
Hi Folks,
I installed a Watts 500800 Recirculation Pump onto my 38 gallon electric water heater in my house.
This setup has been working okay but I'm running out of hot water when filling my 80 gallon jacuzzi.
So, I then purchased a Honeywell AMX300TLF mixing valve and a Honeywell L6006C1018 aquastat controller.
I haven't installed the Aquastat yet but I did get the AMX300 mixing valve installed last night and I disconnected power to my recirculation pump until I get the aquastat installed. You can see in the pic below the water heater tank--> mixing valve--> recirculation pump.
I then cranked up the heat on my 38 gallon tank to the max and set the mixing valve to where hot water coming out of the faucet is about 115*F.
Problem is, I have very reduced water flow. When I first open the hot water, I get correct flow. But within seconds, the flow is reduced by about half.
What do I do to resolve that?
Also, did I buy the wrong Aquastat for my setup?
Not sure how to wire it up to my pump. All the wiring diagrams I'm finding seem to indicate an additional relay is required.
It also wants a dedicated return line but I won't have that installed for another year or two.
If I can get the kinks worked out, I plan to tidy up the install and put a 1" pipe where the flex pipe is.
And mount the aquastat to the 1" pipe. Like in the pic below.
This is all a temporary setup while I continue working on the rest of the house.
See post # 11
Hi Folks,
