Residential Boiler Piping Question
Hockey Nut
Ontario, Canada
Just after the back-flow preventer, there is a piping loop with a pressure reducing regulator that connects directly to the pressure tank.
Should both shut off valves be open? The top shut off valve (yellow arrow) is closed and I haven't been able to find any info on why it should be open or closed.
Any insight would be greatly appreciated.
WorthFlorida
Solutions
Orlando, Florida
It is a bypass valve for the PRR. Not sure why it is there. Always keep it closed.
Hockey Nut
Ontario, Canada
Thanks, appreciate the input. It's a little confusing (I'm no plumber :)) the installation manual (Prestige Solo 110) does not show this loop installation, but newer versions of this boiler model do... Maybe there was a retrofit done in the past to the piping, I'll have to look into that.
Valve closed!
Pics attached for reference.
* I see the open valve position in this diagram... that's where it all started ;)
Hauppauge, NY
It's probably there just to help purge the system of air the system of air. But it's not really needed, and potentially a risk to over pressurise the system and cause the safety relief to open.
