I am in the middle of a bathroom remodel. My next step is to install the subfloor, and I want to get the subfloor as close to the flange/pipe assembly for the toilet as possible. My only issue is that I do not know my finished floor height yet, as I have not decided whether or not I am using an uncoupling membrane and/or what thickness of durock (if any) I am going to use.
So.....I wanted to see what the board would reccomend in this instance.
Should I cut the vertical pipe, then splice a new piece in well above the floor height and adjust/install the flange when I am done with the floor?
Or, since I have access to the toilet area from below, should I just cut the vertical piple down below subfloor level and deal with it later?
Also, flange reccomendations would be appreciated - want a good one that I don't have to worry about.
Thanks for the help.
