pnbhome
I have some questions regarding the replacement of the wax ring under an old toilet:
1. I just replaced the wax ring under an old toilet. The flange was the height of the floor and I used an Wax Extender Kit that claims to have 40% more wax. As I placed the toilet down on the new wax ring, a good deal of pressure was required to make the base sit completely flat on the floor - which took some time and effort. And, as I placed the base down, it seemed to rock slightly on the toilet flange as the wax compressed. Is this normal or, at least, okay?
2. I noticed a very small amount of the wax oozing from under the back of the toilet base on one side. The old ring was just a wax ring only (no encased plastic flange) but it was replaced with a wax ring that contains a plastic flange. Did I use a wax ring that was too big? Should I have used a wax ring only - without an encased plastic flange?
3. I have flushed the toilet numerous times and there have been no signs of any leakage. (I placed paper towels all around the base to detect any moisture. They are all completely dry.) The toilet now sits completely flat and does not rock. Should I be concerned with the items mentioned above - or even replace the wax ring with a smaller one?
4. Finally, there were three commodes in the house when we moved in six years ago. The wax rings for two have now been replaced. The third toilet appears to have no drain problems. Should I preemptively replace the wax ring of the third, even though there a no signs of leaking (no odor or moisture)? Or - don't fix it because it ain't broke?
Thank you very much for any insight and advice you might offer!
