SBpropertiesGA
As part of a remodel I am replacing an older gas range. The new range has a larger diameter flex pipe and fitting than the old one and will not screw into the valve.
Can I use an adapter to make it fit the old valve? Will the range still operate properly if I do? Or should I replace the valve with the larger diameter?
