Hey there, folks. The circuit breaker that powers my dryer has been giving me some trouble. It's an old ITE QT2-3030, with the metal insert that fits the U-shaped anchoring clip on the older ITE breaker boxes (house built in 1963, panel most likely original).
For awhile, the dryer wasn't heating, and the breaker would make a very brief buzzing noise when the dryer was first powered on, but not trip. When I messed with it, I noticed the switch didn't seem to be clicking properly into the off position. After I disconnected and reconnected it, the switch seems to be working properly again and the dryer is heating, but it's still making the buzzing noise, although it's fainter. So that makes me think I should probably go ahead and replace it lest we set my house on fire (please tell me if I'm wrong and a little buzz is normal under the load of a dryer).
I've found a few sources for the correct breaker that will fit the panel so I don't have to do a sketchy rig job with it. What I'm wondering is if I should order two of the QT2-3030s and also replace the newer breaker on the left, which is working fine but isn't a true fit for my panel. Because it doesn't seat completely properly, the pressure of the panel cover is helping to hold it in place, and that sketches me out.
The weird thing to me is that the breaker on the left doesn't have a linkage between the two outer switches. I'm sure it's just an updated version of the same thing (part number Q23030, type QT), but the outer switches can be operated independently. So I just want to be 100% sure that the older QT2-3030 *is* the equivalent of what's there now. The sticker is hard to read in the pics below, but it definitely shows both the inner and the outer switches as linked and 240 V.A.C., NOT the outer switches as single-pole 120s.
(And yes, I know replacing the whole panel would be ideal, but that's above my skill level ... and while I can afford a couple breakers and replace them myself, parts/labor for a full replacement is most likely out of reach for now.)
Here are some pictures of the panel and breakers in question ...
Whole panel, cover off:
Breaker that's buzzing (you can see how the center switch wasn't settling properly into the "OFF" position. It now is.
Panel diagram inside door for good measure (sorry for dark photo, but you get the gist):
