What kind of shower pan and shower construction method are you planning? That will make a difference in how to best attack this.
If it's the top part of a clamping drain, it is normally height adjustable, but you'd have to probably break out some of the mortar around it without damaging the liner before you could raise it. They aren't often interchangeable with a new top.
If you do have a clamping drain assembly, but wanted to convert the shower to a surface applied membrane, Schluter does make a conversion drain that attaches the to base of the clamping drain assembly.
So, without knowing for sure what you have and where you want to go, kind of hard to say for sure.
