rhosch
- Messages
- 8
- Reaction score
- 0
- Points
- 0
So I googled and searched, came across this forum, searched some more and read.
Following the advice given in similar threads, I first tried the internal pipe wrench (couldn't find an easy-out in a big enough size at the local Lowe's), and after that failed to remove the threaded piece (about three or four threads worth, best I can see) I tried the hacksaw and tapping-screwdriver method.
Now I have some saw cuts into the copper elbow threads in a few places, and some pieces of the old shower arm that just refuse to come out. What now? There are enough clearish threads to screw in the new shower arm about three full turns, but even with a lot of pipe tape it drips around the threads. Not sure if that is because it isn't in tight enough, or because there are cuts through threads, or just because the threads are pretty ugly looking now in general (or all three).
Short of cutting a big hole in the drywall and replacing the elbow (which, incidentally, is probably beyond what I'm willing or capable of doing), is there anything else that can be done? Maybe with a smaller, thinner screwdriver, a lot more patience, and a pipe tap when all is done I might could salvage the elbow enough that it won't leak.
I also have a tube of pipe goop - some glue/sealant type stuff. Is that worth even considering? If a handyman or plumber has to fix my mess, how much do you think I'm looking at (drywall behind shower head - no tile)?
