Hey All,
While doing other work in the attic, I noticed a PVC vent line had a little water coming out of an elbow joint during my wife's shower. Since it was relatively accessible, I cut the corner off and installed a new one.
While installing the new corner, it seemed like one of the PVC pieces was way too easy to move into position. In investigating the next joint down the line (which is very difficult to access), I found that the joint was completely loose and freely rotating. No noticeable damage to the pieces, but it just appears that it separated at the joint.
The joints are probably 35 years old and all the glue on them is clear (or yellowish). No purple primer, but I don't know if that was used back that far. There is glue in/on the joint.
Some researching has suggested that I can reglue the joint with generous amounts of primer/glue after cleaning it. But most of the research related to recently glued joints that separated/failed for some reason, rather than 35 year old joints. So is it safe to sand/scrape off what I can of the old glue and reglue the current pieces? Or do I need to look at cutting back and replacing in this inaccessible area?
Again, this is a vent line, no fixtures draining through this section (other than condensed steam).
Thanks,
Tyler
Thanks,
Tyler
