Question about shower valves.
Hugo Strasser
Arizona
We started to redo out shower from scratch and I was looking for a very long time for a suitable shower valve. In Germany we have single lever action valves which regulate volume and temperature at the same time with a nice lever and turn action. I could not find anything similar in the US so I finally settled with a moentrol 3520 valve. It is the closest to what I have in mind although the volume control is a pull and push action which is rather on and off than actually controlling the volume. It does not allow you to fine tune the volume.
By accident I found a Wall Mounted Bathroom Faucet from Vigo that is 100% what I would like to have in our shower and I ask myself what is the difference between a shower valve and a faucet valve. Apart from the fact that this Vigo valve is 5 times cheaper than the moentrol. I understand the Moen valve has temperature stops and is pressure-balancing (I don't need that! ) but other then that what it the difference? And if so why can't I use this faucet valve to control my shower?
Legally, it must be pressure balanced for a shower.
The Moen 3520 is a Moentrol, which controls both volume and temperature, and very nicely too.
A lav wall faucet is dialed down to something like 2 gallons a minute or less, and may not survive on a wet wall.
Hugo Strasser
Arizona
So how much gallons per minute does the 3520 do? I cannot find any info about that.
I bought the Moen 3520 already and I assembled it together with the trim. The Volume control sucks. If you pull the handle at its end you force the valve axis upwards. I don't see how this can do any good to the cartridge and it will certainly shorten it's lifetime.
I do not want to brake any laws of course. Are there any shower valves with the same mixer and volume control action then a faucet valve?
The cartridge in the Moen may go twenty years. And it has a lifetime warranty.
I don't think it's a worry.
Moentrol 3520 @ 60 PSI
Tub port - 7.2 GPM
Shower port -6.3 GPM
  • equipped with the Moentrol® pressure–balancing control valve: control allows you to adjust both water volume and temperature; pressure–balancing feature helps maintain temperature even when other water sources in the house are in use
IF you have a Moentrol, you must not have a very steady hand when you pull on the handle, because all you have to do is STOP pulling when the volume is adequate. There are MANY tub/shower valves, besides the MoenTrol, which control the volume and temperature separately.
Grohe sells some with the features you want in the USA. Delta does as well. I have a Grohe thermostatically controlled valve in my home, and I put in a Delta at my mother's. Both allow you to control volume and temperature separately.
