I have to use a booster pump to get municipal water to my house.
The pump is a Myers that is convertible between 115 and 230 volts and set for 230 volts. I have run 10/2 wire to the pump, which is about 430 feet from the house. Everything works quite well; however, I need to keep it from freezing.
I want to put a light bulb with the pump. As opposed to burying another wire from the house to the pump, it has been suggested that I use one of the legs of the 10/2 wire to supply the light. To do so would mean that the pump will have one leg always hot (that would also be the electricity source for the light). The other leg would be energized when the pressure switch on the pressure tank calls for water. Would this cause a problem for the pump?
Secondly, I have placed the pump about 32 inches under ground to help with the freezing issue. I am curious. Is it better to have the pump at surface-level, or does it really matter?
Would really appreciate any help you can provide.
