Rich_B
- Messages
- 14
- Reaction score
- 0
- Points
- 0
Any idea on what the PSI would be from a 4" submersible well pump (SFS Pro Series)? Manufactured by F.E. Myers
1 HP, 230 Volts, 20 GPM, 9.8 Amps, SF= 1.40, PH=1
Cat No.: 2SFS102-20
The Well is approx. 90 Feet
The Motor is a Franklin Electric Model: 2445089003
I need to change out ( install larger irrigation head nozzles) or double up on the zones since installing the well. It's blowing out some water from the pressure relief valve.
I'm trying to calculate nozzle GPM flow and I don't know the PSI the pump puts out
Thanks for you help
Rich
Cat No.: 2SFS102-20
Thanks for you help
Rich
