Previous owners converted shallow well pump to deep well pump?
Robert Gordien
White Bear Lake MN.
I bought this cabin 3 years ago and starting to take notice of what the pump room anatomy is exactly.
the original desc. of the well installation in 1955 never mentioned how deep the well is. The well pump is a deep 2 pipe system but looks like a injector at the floor level. Was this standard or legal or did the owner just convert because he only had this on hand sometime between? Thanks for your thoughts.
Smooky
North Carolina
Sometimes two pipes go down into the well but with a small casing, there is only one pipe going down and there is a packer ejector that seals the casing so it uses the casing instead of another pipe. That is what it looks like you have. It is a deep well set up.
This illustrates what Smooky described:
index.php
There can be a tailpipe extending down below the leathers that could be as much as 35 ft. The tailpipe could draw water reliably 25 ft below the ejector/jet.
Robert Gordien
White Bear Lake MN.
Thank you so much all for your professional advise, my tank is leaking and plan to replace that this spring and eventually get to the pump when it fails at which I'll have a professional perform.
Robert Gordien
White Bear Lake MN.
"Special" in what way? Home Depot 16 gallon? Should I be concerned about something here? I'm a DIY and know little about wells but looks like something I can handle.
I welcome suggestions?
I know that the vacuum valve will go away and I'll just seal off the the pump connection..correct or am I'm in over my head?
It appears it is a "conventional" tank. One with no diaphragm or bladder. It is smaller than those usually are. You seem to have an AVC with a tube going somewhere, but I could be misinterpreting the photo.
Usually with a conventional tank, something puts air into the water flow. The AVC releases the excess. If you put in a tank with a captive air precharge, you could end up with a bunch of air blasting out of your faucets upon occasion. You might post photos that show the tank and suspected AVC better.
All of the HD tanks I have seen are painted. Doesn't mean they don't have galvanized conventional tanks.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You can use a regular diaphragm type tank with a jet pump. Just remove the AVC Air Volume Control. On jet pumps the AVC injects air into the tank, and you don't need that with a diaphragm tank. Then you can use a PK1A on the pump like the picture and have much stronger pressure and a longer lasting pump system.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
I will post better pic's when I get up there next week, I am considering ''Valveman" suggestion also.
If you don't like the PK1A for any reason we will take it back and refund your money. I don't think you will find any other company so confident in their product as to offer 100% of your money back like we do. Been doing this for 27 years and never got one back from anyone who tried it and saw how it works. :)
