During a recent power outage, I lost water pressure in the house very quickly, which never had been an issue before. Diagnosed as a bad check valve off of the T, replaced the valve, and that issue was resolved. I've lived in this house for 10+ years, and the well system had been 100% trouble-free until the check valve failure. I did some other maintenance checks at this time, and discovered my pressure tank was only at 4 psi after draining the tank to zero system pressure. I was surprised to see this, since I've had no water pressure issues in the house. I added air to the tank to get it up to 28 psi (30/50 pressure switch), and when I turned on the system, didn't notice any change in performance. I did notice that the system only takes ~25 seconds to fill the pressure tank, which should be a minute or more to extend pump life from what I've read. My pressure tank is an Amtrol WX-202 (20 gal) with a 1989 date code on it, which happens to be when my home was built. I did the drawdown test, and I got ~5.25 gallons of water our of it (spec is 6.2 gallons from Amtrol), putting my pump output somewhere~11 gpm. I don't have any info on my well pump in terms of brand/age/hp/etc. I've checked the air pressure in the tank several times again over the past couple of weeks, and it is steady at 28 psi. If I shake the tank when empty, I do not hear any water sloshing around in it, and do not get any water coming from the Schrader valve up top. When the tank is full and do the tap test, it only has water ~1/3 way up, which sounds normal. Outside of the fact that my drawdown volume is a little low, and the tank is over 30 years old, it doesn't seem to be faulty. Logic would say my tank is undersized for my pump output, but with the short ~25 second cycle, I would be surprised that my pump would have lasted 10+ years like this. The math would say I should have a 30 or 40 gallon tank to get the 1 minute minimum run time for the pump flow rate. Anything else I am missing here that would be causing the short cycling? Thanks.
