Pressure tank gooseneck
andysail
Wi
Was looking to replace a gooseneck copper pipe to pressure tank with the fitting in the middle but not at any of the stores around like they used to be, is due to the ease of other means pex etc.. or are they not readily available for another reason.. thanks..
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
There are all kinds of tank crosses. "Gooseneck" makes me think Flexcon. They have a special tee on some of their tanks. If you want to solve all your pump system problems while you are at it, a tank cross it the last thing you need. You can replace the tank itself and everything with one little PK1A kit. Large pressure tanks are no longer the norm. You will get so much stronger constant pressure from the CSV1A in the PK1A kit that you will no longer even need soap in the shower. :)
andysail
Wi
Tks much
