Slugboy6000
Can plumbing run through the studs behind a surface mounted electrical panel?
I've been reading up on the required unobstructed space in front of, above and below a panel. If my surface mount panel sits at shoulder height, can I run copper pipe through the studs closer to the floor? (I'm assuming spray shielding or blocking is a good idea)
-Thanks-
-Thanks-
