ugabulldog
My pump was short cycling so I drained tank (also had to replace sediment filter and fix slow leak) Drain in near bottom of tank but not underneath, so all drained except maybe e few galloons? I got everything hooked back up and let sit for an hour then turned pump back on and it did not take long to cut off so I thought something was wrong. Then I turned on hose to get pump to turn on and it was still cycling for about 20 seconds at 30 psi and 60 psi cut in/off. .....So, I got compressor out to add air, checked shrader valve near top of tank and water came out, I did this 3 or 4 times and now I am really confused. Here is a picture of tank, you can see air control valve abut half way up.
