danielhira
Hello,
I am on well water where the well pump stores water in a 10kgal tank, which is gravity fed to the house. The configuration inside the house is:
main -> check valve -> flologic -> sediment filter -> carbon filter -> softener -> UV -> booster pump -> pressure tank -> house
The issue is that if there is a leak, it will drain water from the pressure tank and the flologic will only cut water once the booster pump kicks on, as opposed to cutting water immediately. Flologic customer service recommended:
main -> check valve -> booster pump -> pressure tank -> flologic -> sediment filter -> carbon filter -> softener -> UV -> house
I found this post which seems to recommend the rearrangement, but I recently had a local plumber tell me _not_ to do what flologic recommended because it would significantly reduce flow to the house. Who should I trust?
